Anyone Use A Video Processor With Their RPTV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-14-2002, 07:31 PM - Thread Starter
McPatrickClan's Avatar
I've always been told that using a video processor on an RPTV is overkill. Anyone else out there that uses a video processor on their RPTV? I run an RP56 DVD player, so my picture is pretty clean.
Do you have questions about life? Ask me.
McPatrickClan is offline
post #2 of 5 Old 04-15-2002, 11:57 AM
zxe018's Avatar
I run a Key Digital Leeza to my Pioneer 510, feeding it 540p via RGBHV
Yes it is overkill but here are my reasons:
1) Price was too good to pass up
2) 540p
3) SDI input (have a Panny RP91 w/ SDI)
4) DVI output
5) Firmware upgrades via RS232 port
6) Key Digital's customer service
7) With its flexibilty, I'm ready for that future front projector.
Chris Yra
zxe018 is offline
post #3 of 5 Old 04-18-2002, 04:05 PM
Darrel Johansen's Avatar
I use a Crystal Image with my 1999 65" Mits. Since this set won't take a progressive DVD player, this is the next best thing. The improvement is great, running at 540p.
If you've got a 480p player, then you probably won't see much improvement with a scaler --at least for DVDs.
Darrel Johansen is offline
post #4 of 5 Old 04-19-2002, 03:20 PM
Robert2413's Avatar
Vigatec Dune with a Barco Retrographics 801s. (It also drives a 50" plasma.) I used to use a Faroudja VP-400 for the Barco. Using a scaler on this class of projector is not overkill. However, given that this is basically a Barco 801s Graphics chassis inside a rear projector assembly (using 8" tubes), my experience may not scale to a consumer rear projector using 7" tubes.
Robert2413 is offline
post #5 of 5 Old 04-20-2002, 07:50 AM
Shawn O's Avatar
I'm waiting for my Omega One to be delivered.It will be used with a Sony 61hs10.I watch a lot of satellite so DCDi will do a much better job than DRC(night and day from what I've read).Also,I will now have 3:2 pulldown which my generation of DRC lacks.
Shawn
Shawn O is offline
Closed Thread Rear Projection Units
