Toshiba 65H80 and geometry - AVS Forum | Home Theater Discussions And Reviews
Old 04-19-2002, 12:56 AM - Thread Starter
kurros's Avatar
The geometry on my display is really bad. It's easily noticible for example by looking at the display in "normal" mode (with the grey bars on the side. The picture is bowed.
I found some ADDR settings on Keohi HDTV to reset the convergence to factory defaults, but that didn't seem to help.
Is there a way to set the geometry to factory defaults in the ADDR menu?
My understanding was that resetting the convergence (there were 6 settings, RGB*HV) would fix the geometry.
I have tried to correct it as best I can manually in the service menu, but I can only do so much. I checked around and the overlay grids cost around $300! Ouch.
Am I just SOL?
kurros is offline
Old 04-20-2002, 11:10 PM
sstephen's Avatar
Liked: 24
I remember seeing someone on the keohi site who said they made their own grid from some sheets they got from walmart.
Maybe do a search for it. You'd save about $290
Scott Stephens
sstephen is offline
Old 04-21-2002, 03:54 PM
Saam47's Avatar
Have you checked over at www.***************.com ? There is a Toshiba Tweaks forum that may have the info you need. I know that for this years models, xxH81 & xxHX81 , you can order a grid for about $40-60(if I remember right).
"We are confronted with insurmountable opportunities!" ... Pogo
Saam47 is offline
