65hm167 heatsink - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-04-2011, 10:14 AM - Thread Starter
dj6190's Avatar
Hello All, I recently took apart my dmd board to toshiba 65hm167 tv to replace dlp chip. My problem is after I took off my heatsink I ended up with four springs (2 short and 2long) and dont remember how they go to put heatsink back on. Thank you all for your help
dj6190 is offline
post #2 of 7 Old 07-11-2011, 12:42 PM
aydu's Avatar
Quoted: 147 Post(s)
Liked: 122
I have this set, but have not attempted a repair.
How hard was it to get to the dlp chip?
Did you get everything back together, including the springs?
Did the repair work?
aydu is offline
post #3 of 7 Old 07-13-2011, 08:25 PM - Thread Starter
dj6190's Avatar
Yes, the repair worked, it was fairly easy. Remove screws and back plate that goes around all the audio/video inputs, remove fan, metal plate, heatsink, and then the dmd board to get to dlp chip. Dlp chip cost me $175.
dj6190 is offline
post #4 of 7 Old 07-14-2011, 12:04 PM
aydu's Avatar
Quoted: 147 Post(s)
Liked: 122
Where did you get the chip from?
Part #?
I'm guessing that you phyically removed the light engine to do the swap, or was the part accessable with just the components you mentioned removed.
aydu is offline
post #5 of 7 Old 07-14-2011, 07:54 PM - Thread Starter
dj6190's Avatar
Part# I used was 4719-001997. It was different # from what my original dlp chip had but it has been working flawless. No need to remove light engine. After removing back plastic plate there is two additional screws that holds light engine component in place. Remove the two two screws to slide light engine assembly out a few inches so you can unplug some wiring. Also the heatsink will have a thermal pad, just get some thermal grease from your nearest computer store in case the thermal pad breaks apart when removing heatsink and also when unscrewing heatsink remember how springs are in place. Then remove components I mentioned in previous post. Found part through shopjimmy.
dj6190 is offline
post #6 of 7 Old 07-15-2011, 07:27 AM
aydu's Avatar
Quoted: 147 Post(s)
Liked: 122
Great instructions.
My set just started to get white dots, but it's covered by an extended warranty. They have ordered parts to fix.
Just curious how extensive the surgery will be.
aydu is offline
post #7 of 7 Old 03-17-2012, 04:14 PM
dman210's Avatar
I followed instructions here to try the dlp chip change myself and I'm at the light engine and I've taken the fan off, but how do I get the metal case off to get to the heat sink and chip? help! missing march madness on the big screen!
thanks
Don
dman210 is offline
Reply Rear Projection Units
