mitsubishi laservue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-20-2011, 02:59 PM - Thread Starter
crush6742's Avatar
I Just purchased a new Laservue last week. There is a constant hum coming from the back of the set. I also hear the fan kick on as well. The hum and the fan are not very loud, but they are very noticable when listening to the TV at low volumes, or when there is silence in the show or movie you are watching. Is this normal? This is my first large screen tv and I'm a little dissapointed with this distraction at low listening levels.
I have a 42" LCD and there is no noise at all coming from it. I can turn the volume down on this set as low as it goes and you don't hear a thing.
crush6742 is offline
post #2 of 9 Old 12-20-2011, 03:13 PM
fuddvd's Avatar
The fan is there to cool the lamp,no getting away from that noise.I'm not sure about the hum though,are you putting the tv power through a battery backup?
fuddvd is offline
post #3 of 9 Old 12-20-2011, 03:36 PM - Thread Starter
crush6742's Avatar
It's plugged into a surge protector. No battery back up. I quess the fan makes sense. I'm not sure what the hum is coming from. It's about a loud as the fan noise. You can here the sound of the fan (which is constant) and the hum (which varies a little bit in pitch) as well.
post #4 of 9 Old 07-16-2012, 03:36 PM
ordo's Avatar
Quoted: 18 Post(s)
New laservue on mits website as of today
ordo is offline
post #5 of 9 Old 08-07-2012, 05:22 PM
ordo's Avatar
Quoted: 18 Post(s)
New Laservue removed from mitsubishi website aas of today. Anyone?????
ordo is offline
post #6 of 9 Old 08-09-2012, 06:26 AM
OneEyedPony's Avatar
Good catch... Mitsubish-TV has removed all information on the LaserVue L75-A96 from their website.
http://www.mitsubishi-tv.com/
Don't B Sharp... Don't B Flat... B Natural!
OneEyedPony is offline
post #7 of 9 Old 08-09-2012, 04:10 PM
Augerhandle's Avatar
Quoted: 747 Post(s)
Liked: 649
They are probably just updating the specs.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #8 of 9 Old 08-09-2012, 10:03 PM
CarbonJoe's Avatar
It's back now....
CarbonJoe is offline
post #9 of 9 Old 08-10-2012, 12:26 PM
Quoted: 747 Post(s)
Liked: 649
See?
Reply Rear Projection Units
