Mitsubishi: DEFECT in 2011 DLP Sets/fix - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 146 Old 05-26-2012, 09:32 PM
ILOVEMYHDTV's Avatar
Quoted: 52 Post(s)
Liked: 50
hi all. i have updated my 640 before..but sense I have upgraded my laptop; tried to download i keep on getting. failed attempt do to something about " Change the association in your preferences" can any explain..?
PS3+4= CHiNGOBLiNG = RUBEN...YOU NEED TO OPEN YOUR EYES TO SEE THE PICTURE!!... "SHOE MAKER HOME THEATER".7/22/16....just a KLIPSCH NUT..>7/22/16...2new videos show..https://www.youtube.com/watch?v=jWO0YtCWQxI.....https://www.youtube.com/watch?v=yIen05Wcg9w. u can even look from when I started about to present day.... i stutter sometimes....
ILOVEMYHDTV is offline
post #122 of 146 Old 05-26-2012, 09:47 PM
Quoted: 52 Post(s)
Liked: 50
forget it, sometimes i'm to stupid for my own good. just change web browser download successful and on thumb drive ready for updating. oops i realized that i extracted to a sd card...OK. now on thumb drive an tv is doing it thing now.... an BINGO !! 13.06 is listed on the menu ....
post #123 of 146 Old 05-27-2012, 07:34 PM
KingLou's Avatar
Does this defect apply to the A94 LaserVue? And is the 13.06 firmware version compatible with it?
Under downloads section on the Mitsu site for the A94, the 13.03 version as listed as being the most up to date. I don't want to brick my brand new TV with firmware that's not compatible.
KingLou is offline
post #124 of 146 Old 05-27-2012, 08:44 PM
yadfgp's Avatar
Quoted: 67 Post(s)
Liked: 68
I dunno on the defect with your TV. But I do know you definitely do not want to update your TV with a firmware not listed as being compatible with your TV. If the 13.03 is listed by Mits as being the most recent, then just stick with that.
The defect some people had with their TV's in this thread can be very easy to see. All the pertinent info can be found in the 1st page.
yadfgp is offline
post #125 of 146 Old 06-01-2012, 08:59 PM
Infinitro's Avatar
I know this has probably been covered, but I missed it. Can someone send me the mitsu 13.06 update in a zip file. I have been trying for weeks, but it comes back as a utv file with an adobe association that is not a zip file. Can't open it. Can't fix it. Can't use it and almost ready to quit even trying. I must have missed something some where. Thanks for any info you can give me.
Infinitro is offline
post #126 of 146 Old 06-02-2012, 09:11 PM
Augerhandle's Avatar
Quoted: 876 Post(s)
Liked: 803
http://www.avsforum.com/avs-vb/showt...4#post22029434
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #127 of 146 Old 06-03-2012, 12:18 PM
eboy0's Avatar
Forgot to update this thread.
Basically, the repair company showed up, very professional and prompt. Tech seemed to be very knowledged in TVs and answered all my questions.
He told me basically, the reason why my TV wouldn't take the 13.06 update was due to the memory being full. I told him about the flashing green LED I received a month or so ago, and he ordered me up a mainboard.
2 days before they called me to install the mainboard, I received the flashing green LED again, coincidence right?
Tech came, I showed him the flashing green LED thing, he replaced the mainboard, TV turned on normally, running 13.06 firmware.
So all in all I'm happy, since the TV is under warranty. I'd really hate for this thing to crap out with the mainboard after the warranty expires.
eboy0 is offline
post #128 of 146 Old 09-19-2012, 11:25 AM
KevinCTG's Avatar
Hello,
I am expecting to receive my 82740 tomorrow and just stumbled onto this page while doing some research. Is it safe to assume that I will have to update my firmware or has there been any reports of this model being free of defects?
Kevin
KevinCTG is offline
post #129 of 146 Old 09-19-2012, 12:05 PM
GEP
GEP's Avatar
Assume nothing. Check the software level. Press MENU and look at the lower left hand corner. The Mitsubsihi web site shows that the current software is 013.06. If that is shown on your TV, then no new update is available.
Also if you connect up to the internet and stay connected to use the internet (by connect up and stay connect I mean the eithernet cable is connected to the TV or you have the optional wireless adapter in the USB slot and paired to your home wireless router), then you get the updates automatically.
In the history of TVs and in the history of Software there has never been a "defect free" TV or software. It is just the defects may be self correcting or occur so infrequently that most people do not see them as a defect. 013.06 has been out for a long time so it seems that software bugs that seem to cause problems have been fixed. As for a TV that will not fail, that is impossible but on the whole these TVs have been reliable.
If there was a TV design that will not fail, there would be no such thing as TV Repair shops.
GEP is offline
post #130 of 146 Old 09-22-2012, 10:22 AM
KevinCTG's Avatar
Thanks for the feedback sir. Got the TV two days ago with no problems in shipping from Pauls TV. The manufacture date on mine is March 2012 and it came with firmware ver. 13.05. I corrected the date and time and left the TV hooked up to my router overnight and it auto updated by the time i powered the tv on the next morning. Overall i have no complaints thus far. Im going to be getting an ISF calibration done next week so i will post my results with that when it happens.
KevinCTG is offline
post #131 of 146 Old 09-24-2012, 06:31 AM
KevinCTG's Avatar
After spending a weekend with the TV, I have noticed a pretty extreme "bowing" on the top left corner of the screen. It is only noticeable when their is a horizontal line across the top of the screen (very noticeable when watching DirecTV and the info panel is displayed). Any ideas on if this is something I have to live with or if Mits would honor this under warranty?
KevinCTG is offline
post #132 of 146 Old 12-19-2013, 11:50 AM
Quoted: 876 Post(s)
Liked: 803
Originally Posted by maineiac13 View Post
I have the 82740 and as others have noted with the pictures above, the same defect appears on my tv.
My 2008 WD-65835 has been recently updated with a new DMD chip and now has this defect! Anyone else with a new chip have this issue?
post #133 of 146 Old 12-19-2013, 05:10 PM
Witchboard's Avatar
Quoted: 152 Post(s)
Liked: 100
Did you try updating the date/time on the set since the replacement and see if it pushes an updated firmware? What's the current version of FW on your set?
Witchboard is offline
post #134 of 146 Old 12-20-2013, 02:52 AM
Quoted: 876 Post(s)
Liked: 803
The set doesn't have an ethernet connection. Current firmware is 10.00, and I heard 10.04 is available, but I can't find it on Mitsubishi's website.
I can't seem to get the firmware idea through to the people at the call center either.
post #135 of 146 Old 12-20-2013, 08:15 AM
Witchboard's Avatar
Quoted: 152 Post(s)
Liked: 100
Yeah, the only downloadable content for your set I see from Mitsubishi is the dimension sheet, spec sheet and owner's guide. If it's not on the website, support is the only way I'd think you would get it. Unfortunately it looks like you're having an issue with them. Call back, you'll eventually get somebody that knows what you're looking for. Good luck.
post #136 of 146 Old 12-23-2013, 01:44 PM
Quoted: 876 Post(s)
Liked: 803
So has anyone else with a new DMD chip have this defect?
post #137 of 146 Old 12-28-2013, 09:44 AM
njfoses's Avatar
Quoted: 159 Post(s)
Liked: 109
I have the white pixel issue on my 73835 and need to order a new dmd chip soon. Your post now scares me a bit. There seem to be a few different model #'s of the chip that are compatible with the 835 series. Which one did you order? Maybe the issue is tied to a specific chip?
njfoses is offline
post #138 of 146 Old 12-28-2013, 05:26 PM
Quoted: 876 Post(s)
Liked: 803
I don't have the part #. Mitsubishi handled it all.
post #139 of 146 Old 03-21-2014, 04:13 PM
Quoted: 876 Post(s)
Liked: 803
Here's some pics after chip replacement.
post #140 of 146 Old 03-25-2014, 04:47 PM
JP32's Avatar
Quoted: 45 Post(s)
Man, I forget about this thread for about a year... stumble back upon it, and a new problem has popped up?
What exactly is this defect? Is it the exact same thing as before (seems a bit different judging from the pics)? I get that it happens after you had the dmd chip replaced... but could you guys expand on the explanation?
My 736540 has been running perfectly ever since the FW update (knock on wood). Only had to replace the original lamp a few months ago.... still in love with this set. I'm not looking forward to replacing it when it does decide to die.
JP32 is offline
post #141 of 146 Old 11-01-2015, 04:33 AM
Jan J's Avatar
Quoted: 39 Post(s)
Fast forward 4 years
Just to prove that this thread is not dead... Let's fast forward this thread to October 2015.
We had a board die in the 73640 (All HDMI Ports went dead), and when we finally got the serviceguy to replace the board, the replacement board did NOT have 13.06 installed in it!
Believe it or not, we had to wait for this board to be made, as it was "Back Ordered"!
Serviceguy didn't know anything about the uniqueness of V13.06 firmware, and didn't have or know how to install it... So I showed him.....
V13.06 installed successfully in the repaired 73640...
Looking for a 1939 Indian Motocycle
Jan J is offline
post #142 of 146 Old 11-01-2015, 09:21 AM
Witchboard's Avatar
Quoted: 152 Post(s)
Liked: 100
I presume you upgraded manually from USB since you showed him?
post #143 of 146 Old 11-01-2015, 03:34 PM
Jan J's Avatar
Quoted: 39 Post(s)
Yes... and he had never seen it happen before!
What I'm trying to get across is that on a board had had to be back ordered and newly made, they are not putting the latest and greatest firmware in it!!! THAT IS SCAREY!!!
Jan J is offline
post #144 of 146 Old 11-01-2015, 04:10 PM
Witchboard's Avatar
Quoted: 152 Post(s)
Liked: 100
I was just curious if the auto update still worked from the net.
post #145 of 146 Old 11-01-2015, 06:14 PM
|Tch0rT|'s Avatar
Quoted: 186 Post(s)
Liked: 130
The xx640 are not the smart TV style like the other models from that year so it lacks that feature. USB is the only way to update the firmware.
My Home Theater/Video Gaming/HTPC/2 Channel rig (Mitsubishi, MartinLogan, Marantz, DIYMA, and others)
|Tch0rT| is offline
post #146 of 146 Old 11-01-2015, 07:23 PM
Witchboard's Avatar
Quoted: 152 Post(s)
Liked: 100
That is incorrect. Mine updated automatically from the internet when I set my clock to the correct time.
I stand corrected, my model is a xx740.
Reply Rear Projection Units
