Help Broken Mirror - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-16-2012, 01:00 PM - Thread Starter
djb1940's Avatar
Please help, while I was moving my Pioneer Elete PRO700HD from room to room I had to take the back off. Doing so I broke the mirror. I can buy an acrylic mirror 1/8" x 24" x36" ($30) I understand the original its not a "pure" rectangle. To buy a new from Pioneer would cost over $ 200. I'm retired and 72 years old now and just can't afford . I Was going to get a locate Technician to cut it and install it. any body got any info/ideas that might help? Thanks
djb1940 is offline
post #2 of 4 Old 04-16-2012, 03:54 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
you might looking thru your used ads for your location (on-line) to see if someone is "turfing" a old projection screen tv ... or put in a "wanted" ad... you might get lucky and salvage a mirror for little or no cost. Further, phone a few repair shops. Sometimes they might a have a mirror "lying around" from a non-serviceable set (or customer gave up on). Lastly, the mirror in RPTV's is "special"... its a first surface reflector (ie. silvered on the face). A regular mirror isn't going to work well.... hopefully your acrylic one is the right type.
budwich is offline
post #3 of 4 Old 04-16-2012, 04:11 PM
gregzoll's Avatar
Liked: 33
Also check with the local electronics recyclers. They may be able to salvage a mirror before the junk the whole set. Also check the local Habitat retail store if you have one. You can usually find the parts online through ebay or on Craigslist pretty cheap.
gregzoll is offline
post #4 of 4 Old 04-17-2012, 06:54 AM
sideswiper's Avatar
hope you didnt damage or scratched the projection guns as thats what your mirror would fall on
sideswiper is offline
Reply Rear Projection Units
