VS-50609 mitsubishi - AVS | Home Theater Discussions And Reviews
post #1 of 10 Old 05-11-2012, 03:01 PM - Thread Starter
Urlee's Avatar
I have a 50" big screen Mitsubishi model VS-50609 bought in 2001.
All of a sudden, I can no longer watch TV. Just hash (snow).
I was watching a recorded program on my stand alone DVR and when done, I switched back to TV and no picture on any channel.
I can get all my channels to watch with the DVR on but nothing if the DVR is off. Am I using the tuner of the DVR in that respect?
Could it be the Tuner of the TV that failed?
I am on cable TV. My bedroom TV works fine.
Urlee is offline
post #2 of 10 Old 05-13-2012, 05:10 AM
videobruce's Avatar
Quoted: 414 Post(s)
Liked: 199
Probably.
Do you see the channels in the channel list? Try doing a channel scan? Try a full reset.
Abundant OTA television is what makes this country different from all others. Lets keep it this way. If you like Wi-Fi so much, OTA fits right in. After all, it is wireless.
videobruce is offline
post #3 of 10 Old 05-13-2012, 03:03 PM - Thread Starter
Urlee's Avatar
I have an Antenna A and B connection point. I connected my incoming Cable to the B and did a search with no luck so I connected back up to A and did a scan for our channels and as before, No luck. Just snowy screen.
I am now searching, trying to find something to my liking to replace that TV. Being it is analog, I figure time to let it go.
Urlee is offline
post #4 of 10 Old 05-14-2012, 03:58 AM
videobruce's Avatar
Quoted: 414 Post(s)
Liked: 199
Ok, the tuner went south, but the rest is ok, correct?
post #5 of 10 Old 05-20-2012, 11:49 AM - Thread Starter
Urlee's Avatar
Yes, Everything else works OK. (Inputs,Pip, etc.)
Should I "Gut it" and use the cabinet for an LED flat screen?
Urlee is offline
post #6 of 10 Old 05-21-2012, 04:41 AM
videobruce's Avatar
Quoted: 414 Post(s)
Liked: 199
If you like it, why not use it as is w/o the tuner?
Gutting it would be a waste of time, try to sell it or just put it to the curb.
post #7 of 10 Old 05-24-2012, 12:06 PM
2 Bunny's Avatar
I hardly use the antenna/cable inputs on our set. If I were you, I'd just not use the antenna/cable inputs and use the component video plugs only.
- 2 Bunny
2 Bunny is offline
post #8 of 10 Old 05-26-2012, 11:31 AM - Thread Starter
Urlee's Avatar
Because I can't watch TV while a program is being recorded and it is a pain having to use a remote (the DVR) that does not have the features that the TV remote has like jump button, pip, info, etc, etc. Plus----Having to have the DVR on all the time to watch TV.
Urlee is offline
post #9 of 10 Old 05-26-2012, 11:36 AM
videobruce's Avatar
Quoted: 414 Post(s)
Liked: 199
Ok, just buy a outboard tuner.
I have a ePVision PHD-205 for sale. PM me if interested.
post #10 of 10 Old 05-26-2012, 11:43 AM - Thread Starter
Urlee's Avatar
- 2 Bunny
I am on cable TV and have to use the cable Input in order to receive the stations from the TV provider. With the company's cable, I plug into the Input of the DVR and with another cable from the Output of the DVR to the Input of the TV.
Urlee is offline
Reply Rear Projection Units
