Toshiba 57h93 flashing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-17-2012, 12:11 PM - Thread Starter
Haapala's Avatar
Greetings,
Our toshiba 57h93 has been suffering from an intermittent loud clicking noise in conjunction with a screen flash. I was wondering if anyone has seen a similar problem and corrected it? The set is becoming worse and I would really like to repair it, it has a great picture!
Haapy
Haapala is offline
post #2 of 5 Old 05-17-2012, 12:57 PM
Augerhandle's Avatar
Quoted: 751 Post(s)
Liked: 651
Originally Posted by Haapala View Post
Greetings,
Haapy
From your description, I would suspect the flyback transformer is arcing. You can find help here: http://www.avsforum.com/avs-vb/showthread.php?t=695922
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #3 of 5 Old 05-17-2012, 01:34 PM - Thread Starter
Haapala's Avatar
Thanks Augerhandle!,
I Believe I know what and where these puppies are, is there a quick way to test for the failing unit?
Haapy
Haapala is offline
post #4 of 5 Old 05-17-2012, 01:48 PM
Quoted: 751 Post(s)
Liked: 651
Haapy
Usually, if it's arcing, it's failing.
Because of the danger, I do not recommend messing with it yourself.
There is a fatal shock hazard of over 30,000 volts even with the TV off and unplugged, so I'd recommend posting in the thread I linked to. You will get both answers and safety procedures to troubleshoot and fix the problem.
post #5 of 5 Old 05-17-2012, 01:53 PM - Thread Starter
Haapala's Avatar
Thanks, will do.
Haapala is offline
Reply Rear Projection Units
