Samsung hlp 5085 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-27-2012, 10:57 PM - Thread Starter
esj
esj's Avatar
have a series of black thin vertical lines,there is 8 lines per group with a total of 10 groups,each group has a aprrox 3 inch space between them,any idea what this may be,hopefully nothing expensive,this unit operated perfect for 7-8 years,just turned it on today and got this issue,please if you may know this problem reply,thank you
esj is offline
post #2 of 5 Old 06-01-2012, 12:08 PM
conquer1's Avatar
Doesn't seems like anyone knows. I've got the same issue with a Mitsu DLP that I've had for a year and a half.
I turned it on last Saturday, and I got black vertical lines going all across the screen that resemble a bar code.
Hopefully, someone can help both of us out.
conquer1 is offline
post #3 of 5 Old 06-01-2012, 02:31 PM - Thread Starter
esj
esj's Avatar
if you have what looks like vertical musical notes / lines this would be a bad dmd / control board,2 repairman have said so and from what i see on the net it looks like this dlp is headed for the grave yard as i`m not spending 800 bucks to repair,anyone in new york want this come and get it ! hopefully i have better luck with a led unit,got 7 plus years from this dlp
esj is offline
post #4 of 5 Old 08-08-2012, 02:19 PM - Thread Starter
esj
esj's Avatar
no one replys here,seems to be a wasteland on dlp models these days, 7 years old and already a dinosaur in this electronic world lmfao !
esj is offline
post #5 of 5 Old 11-18-2012, 03:36 PM
jaws02's Avatar
I have the same TV but my set has also recently had issues after it worked for years (my DMD PCB board - part # BP96-00696A) stopped functioning. I was also told the part would cost around $390. All other parts are working fine, but it looks like my DLP may also RIP since the cost to fix is quite a bit...
If you find any additional info about it, please let me know! Good luck.
J
jaws02 is offline
Reply Rear Projection Units
