Samsung HLR-4667 has no sound or picture but lamp does light. - AVS Forum
post #1 of 4 Old 06-13-2012, 12:38 PM - Thread Starter
iskowitzsa's Avatar
I have a Samsung HLR-4667W DLP TV that is not working.
When I turn on the TV the lamp does come on but I have no picture or sound. I hear a Click after about two seconds and I can see the lamp turning on in the back (have the rear cover off but do have the interlock switch cheated).
The TV lamp light on the front will blink for 19 times, then pause and blink for another 11 times. Then after a while it will turn off. When I use the remote and push any button all the light indicator in the front will flash “TIMER”. Tried to hook up different devices to the other inputs, ie, DVD's etc and pushed the source button on the remote to see if something happened but nothing did. Even pulled out the Color Wheel to see if it was good and it does spin when pushed, very slowly but is not free wheeling. Help! Any help would be appreciated. Including service manual info or flow chart etc.
iskowitzsa is offline
post #2 of 4 Old 06-13-2012, 01:17 PM
Augerhandle's Avatar
Liked: 47
Samsung has an online troubleshooting guide
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=34&modelname=HL-R4667W&modelcode=&session_id=PYzY1SJtTHTWrp0b618x51mQgkL2RXndKF313YdW9tMy5xFJJ1hJ%21858796491%21-1240397946%211339618072089
With specific information here
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=146588&modelname=HL-R4667W&modelcode=&session_id=PYzY1SJtTHTWrp0b618x51mQgkL2RXndKF313YdW9tMy5xFJJ1hJ%21858796491%21-1240397946%211339618072089
I would reseat the lamp and close the door properly. If it still fails to operate correctly, you need to make a service call.
EDIT: After researching further, poorly seated lamps and aftermarket lamps from "discount" sites can cause the problem as well, even if they light up. I would replace the lamp with a Samsung lamp first.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
Augerhandle is offline
post #3 of 4 Old 06-13-2012, 05:08 PM - Thread Starter
iskowitzsa's Avatar
Checked out the links you supplied and did not find anything that helped. Sorry. You mentioned reseating the lamp. My lamp is on. If it is on would not that eliminate the reseating of the lamp.
Have no sound and when it is on do have a glow on the screen but no picture. Would the color wheel not rotating at its full speed still allow the lamp to light but no pic and sound?
post #4 of 4 Old 06-13-2012, 09:39 PM
Liked: 47
Nothing helped? Which lights are blinking? According to the second link I posted:
If the Standby/Temp light and the Timer light are blinking, the Cooling Fan is not working correctly
If the Standby/Temp light and the Lamp light are blinking, the Lamp Cover is not properly shut
If only the Standby/Temp light is blinking, the inner temperature is too high
If all three of the Standby/Temp light, the Timer light, and the Lamp light are blinking, the Lamp may be defective.
Reseating the lamp was already explained:
Originally Posted by Augerhandle View Post
...EDIT: After researching further, poorly seated lamps and aftermarket lamps from "discount" sites can cause the problem as well, even if they light up. I would replace the lamp with a Samsung lamp first.
Reply Rear Projection Units
User Tag List
