Need help finding a new bulb - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-20-2012, 04:42 PM - Thread Starter
jarias2311's Avatar
Hey guys,
So I have had my Samsung DLP TV for about 4 years now and the original bulb is STILL kicking! I am about to sell this baby as I just bought the new Panasonic VT50. With that being said, I am a little worried that once I sell the Samsung, the lamp will burn out. Do you guys have any good experiences with any online site?! My lamp code is BP96-01653A (P132W) I would really appreciate your help!
jarias2311 is offline
post #2 of 3 Old 06-21-2012, 06:39 AM
aydu's Avatar
Quoted: 146 Post(s)
Liked: 121
My experience with buying lamps from on-line vendors has not been good. The ads are cleverly worded to imply that you are buying an official manufacturer's lamp.
In reality, you are buying a Chinese knock off version of the lamp.
I went through a half dozen of these lamps from a well recognized vendor. None of them worked more than a few weeks before developing problems. Fortunately the vendor kept replacing them before finally suggesting that I try a lamp from the manufacturer - even though there is "no difference" in performance between what they sell and the manufacturer.
I got one directly from the manufacturer. installed it, and haven't had an issue since.
With DLP lamps, price does not always equal value.
aydu is offline
post #3 of 3 Old 06-22-2012, 04:35 PM
Augerhandle's Avatar
Quoted: 847 Post(s)
Liked: 774
+1
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
Reply Rear Projection Units
