Samsung HLS6187W - Weird Problem Happenings - In Need Tech Expert For This One - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-03-2012, 09:24 AM - Thread Starter
Satman858's Avatar
I woke up this morning and turned on my Samsung HLS6187W DLP HDTV, and some weird things are happening. When I turn on the TV, in the front panel of the TV the "Lamp" light comes on, fine there, but when I press any button on the remote control, volume, source, menu, and even the power button, nothing functions. I even tried the buttons on the front TV panel, and still nothing functions. The only thing that happens is, each time I tap a button either on the remote or front panel, the front panel "Timer" light blinks with each tap of a button. Also, what is happening on the TV is, the picture freezes for about 1 second every 20-30 seconds followed by a 1/2 second black screen, then after about 5 minutes of the TV being on, it then shuts itself down completely.
Is there anyone that knows what is causing these problems?
To me I think it might be some kind of computer malfunction in the TV, but then I am no TV tech.
Any and all help will be deeply appreciated.
Satman858 is offline
post #2 of 4 Old 07-06-2012, 12:57 PM - Thread Starter
Satman858's Avatar
23 views of my thread and not a single reply. I thought they had knowledgeable people at AVSforum, but I guess not. cool.gif
post #3 of 4 Old 07-06-2012, 05:51 PM
gmanhdtv's Avatar
Quoted: 30 Post(s)
How old is the lamp in the tv?
Could be lamp, power supply or color wheel. Start with the lamp.
gmanhdtv is offline
post #4 of 4 Old 07-12-2012, 02:40 PM - Thread Starter
Satman858's Avatar
Well gmanhdtv, the Lamp that was in the TV when I started having problems is 2 1/2 years old. I had an old lamp with housing in my garage that was I had in it before the light engine was changed in 2007, and tried that Lamp, but it will only stay lit for about a minute or two before going out. So I took the back cover off completely, and after vacuuming some of the dust in and around everything back there, I put the 2 1/2 year old lamp back in, and the lamp light stayed on, (which leads me to believe the Lamp is ok) but the screen stays black, except for a very occasional (about every 30-60 seconds) a white horizontal line comes up for about a 1/2 second, then after about 5 minutes the Lamp shuts off. I still have no remote control or front panel functions, (even by not being able to turn off the TV) except when I touch the keys, the front panel "Timer" light flashes with each touch of a key. Since there is no button functions I can not get into the TV menu, but since the TV now has a black screen, I guess getting in the menu does not matter anyway.
Any and all help from anyone else too would be appreciated.
Reply Rear Projection Units
