still no reds after replacing vivitek colorwheel 56" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-09-2012, 01:15 AM - Thread Starter
manof1002voices's Avatar
Vivitek dlp56-22A
I replaced the bulb ( a few months ago) and colorwheel but it didnt fix the lack of reds. Basic menu adjustments do nothing. there are also some issues with over exposure on bright and or white colors..... and some slight ghosting on the screen with that screen is completely black it looks like there are a few clouds in the background.
color wheel seems to be making some noise now also which wasn't there before. I bought it from the only place that had it online and they said once you open the package there is no refunds
please help.!
is it something I need to reset!?!
Thanks you all for your. I took lots of pictures of the inside of the tv when I have a part if that will help...
Thank you!
manof1002voices is offline
post #2 of 3 Old 07-09-2012, 08:46 PM
Augerhandle's Avatar
Quoted: 752 Post(s)
Liked: 651
Sorry you wasted your money, but the color wheel can't cause lack of reds (unless the red filter mysteriously disappeared off the wheel). Time to get a qualified technician to have a look.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #3 of 3 Old 07-09-2012, 09:56 PM - Thread Starter
Does anyone know what could cause this issue?
Reply Rear Projection Units
Vivitek
