Mitsu 57734 DLP very dark picture!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-14-2012, 09:23 PM - Thread Starter
03Cobra's Avatar
Ok all of a sudden my Mitsu 57734 DLP is just too dark, I put in a new Light engine last year I believe and I bought a Mitsu replacement not a off brand cheapo lol....Any way it seemed to me shortly after that the picture is just so dark and I have everything Maxed out on it as far as what would make it brighter. I don't know what the problem could be but as if now if there is just normal outside light coming into the room I cannot even see whats on the screen hardly. So is there any secret settings I can get into to adjust the brightness or do you think a part has gone bad not allowing max brightness---need some advice before I have to take to dealer which I dont want to do lol
When I get this fixed Im done with Mitsu and DLP and getting me LCD or LED----Hmmmm I have to study up on those~
03Cobra is offline
post #2 of 4 Old 07-17-2012, 08:44 AM - Thread Starter
03Cobra's Avatar
really----No idea guys???
I was told by my Mitsu dealer it could be the bulb just going dimmer and getting ready to go---its not that old though but I guess I could have gotten a ****tt bulb??
03Cobra is offline
post #3 of 4 Old 07-17-2012, 09:03 AM
fubdap's Avatar
I think you need new lamp. It will make your TV look like new.
fubdap is offline
post #4 of 4 Old 07-17-2012, 07:48 PM
Augerhandle's Avatar
Quoted: 771 Post(s)
Liked: 663
Mosts definitely seems a new lamp is in order. https://mitsuparts.3diamonds.com/PartsForModel.aspx
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
Reply Rear Projection Units
