Toshiba 52HM84 - AVS Forum | Home Theater Discussions And Reviews
Old 07-16-2012, 08:19 AM - Thread Starter
gamemaker825's Avatar
Hi can a Toshiba 52HM84 work with out a lamp unit, because i found this tv and it has no lamp unit, and iv been looking on the net and can only find ones that cost alot, what should i do to make this tv work, if i can make it work with out a unit then please tell me how thanks for your time.
gamemaker825 is offline
Old 07-16-2012, 09:30 AM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Nope unless I suppose you could try a couple of ridiculously bright led flashlights.
That's if your brave and don't mind possibly starting an electrical fire biggrin.gif
Mik James is offline
Toshiba 52hm84 120 Watt Tv Lamp Replacement
