Strobing/Flickering issue on Samsung HLS4676S DLP - AVS Forum | Home Theater Discussions And Reviews
Old 07-23-2012, 06:21 PM - Thread Starter
IthacaIsGorges's Avatar
Over the past few weeks I've noticed a flickering/strobing on some areas of the screen. I would post a video, but it isn't noticeable on a recording. I've done a lot of searching online and haven't found a definitive solution. I watch a lot of baseball games, and it's most noticeable when the batter is hitting. The flickering occurs along the baselines and against the backstop.
I've had the TV about 6 years now, so far the following has been replaced (main tv, used all the time):
- lamp & color wheel about 5 years ago
-processor/chip?? whatever fixed the "white dots issue", they replaced those parts.
- lamp/bulb again 14 months ago (philips bulb from amazon)
My guesses from doing some research:
-possibly could be the color wheel, even though the tv turns on fine and stays on & there's no "buzzing"
-bulb is running too hot, even though I can see the fan blowing
-bulb is starting to go, and will eventually just need to be replaced.
-or something else that i'm missing?
I'd rather not have to buy a bunch of parts without having it fix the issue...but if internet diagnosing doesn't work, I may have to pony up the $$ mad.gif
IthacaIsGorges is offline
Old 07-24-2012, 03:44 PM
Augerhandle's Avatar
Quoted: 763 Post(s)
Liked: 660
I have seen many posts here where the flickering was caused by a failing lamp, or even a new aftermarket lamp. A lamp replacement being the cheapest option, I would recommend changing the lamp before you try anything else.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
Old 08-07-2012, 05:22 PM - Thread Starter
I just replaced the lamp, and the same issue is still there.
This issue doesn't sound like a color wheel problem, as it never buzzes and doesn't have problems turning on ever.
I got this TV 6 years ago for about $900....so I'm hesitant to start throwing down money on more parts and not having it fix the issue.
Does anybody have a general idea on how Samsung repair places are to troubleshoot issues? A new TV may be in my future if it's too expensive to repair...
Old 08-08-2012, 01:07 PM
Quoted: 763 Post(s)
Liked: 660
Did you replace the lamp with an OEM lamp? Aftermarket lamps are notorious for flickering and other problems.
