Aware me Samsung HL61A650 vs Mits WD-65638 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-02-2012, 09:47 PM - Thread Starter
jhferry's Avatar
Quoted: 35 Post(s)
So my samsung took a hit and the insurance company is offering the WD-65638 as a replacement. Can anyone compare the picture quality of the sets? I cannot find a contrast ratio on the WD-65638 so I was wondering about black levels etc.
The insurance company is telling me these are still made although they are 2010 sets?
jhferry is offline
post #2 of 5 Old 08-03-2012, 04:51 AM
Low Tech's Avatar
From the reviews on Cnet, I would not buy the WD-65638. See if they would reimburse you money instead of the replacement.
It would be better to pick a better tv and pay a little extra out of your pocket.
Yes, my 2010 Panasonic 42C2 performs better than an S2 No floating blacks and keeps the lowest black levels.
Low Tech is offline
post #3 of 5 Old 08-03-2012, 09:07 AM - Thread Starter
jhferry's Avatar
Quoted: 35 Post(s)
I read those reviews along with tigerdirect, amazon and best buy. Most of the negs are due to the bulb which I am already used to. The insurance company is really scumming me. Because Mits still makes a DLP they are using that cost as my full payout value which is around $1100. I can't touch a 61" for that. If they pay me out it is at a reduced value which isnt even close. To get that value I have to get a new TV.
jhferry is offline
post #4 of 5 Old 08-04-2012, 08:16 AM
Augerhandle's Avatar
Quoted: 877 Post(s)
Liked: 808
Tell them you checked, and the 638 series are 2010 models. Tell them you want at least a 2011 model. You can get a 73" (WD-73640) for under $1200, and they can get it cheaper. DLPs are much nicer now and you'll notice the improvement, even if you end up with the 638 series.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #5 of 5 Old 08-04-2012, 01:56 PM - Thread Starter
jhferry's Avatar
Quoted: 35 Post(s)
Yeah I will do that. That cash out value is $700 so I almost would rather take that and bank it for now with everything coming out in the next few years. Fortunately I have a LCD in the other room that survived. Kind of torn on dealing with DLP again as well. W'ell see.
jhferry is offline
Reply Rear Projection Units
