Mitsubishi WD-52327 DLP TV not showing video from any source - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-03-2012, 01:45 AM - Thread Starter
niraj246's Avatar
I've Mitsubishi WD-52327 DLP TV. It doesn't show video from any source and keeps showing the default blue screen. I tried several different inputs but same result. This is a recent problem. On-screen menu works fine. What needs to be done?
PS: When I tried hooking up my PC directly to it using DVI, it showed the boot screen (I think it's 480p). But stopped showing any video when the PC booted. Previously it used to show the video at 1080i where I used to see my Win7 desktop.
niraj246 is offline
post #2 of 2 Old 08-03-2012, 07:59 AM
Low Tech's Avatar
You can give it a try by unplugging the tv for at least 2 minutes.
Depending on brown outs and dirty power, It may be that your tv has a glitch within its internal settings.
All newer A/V components are on while plugged in (standby mode). Thus allowing some corruption to happen with how the circuitry operates.
The only way to clear out the corruption without doing a full reset and loosing your settings, is to unplug to power down.
Yes, my 2010 Panasonic 42C2 performs better than an S2 No floating blacks and keeps the lowest black levels.
Low Tech is offline
Reply Rear Projection Units
