Water behind the screen! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-06-2012, 05:07 PM - Thread Starter
SpiritWolfen's Avatar
I recently purchased a Toshiba 65H84 off craigslist and rain moved through during transport. I did my best to keep the screen and other parts protected, but water got behind the screen! The TV works fine but I want the water out of there. Does anyone know how t remove the bezel so I can get the water out of there?
Also The TV is just slightly too tall to get up my stairs? Is there a safe way to remove the speaker system so I can separate the base from the monitor? It's literally a matter of inches to get it upstaurs.
SpiritWolfen is offline
post #2 of 2 Old 08-07-2012, 01:06 PM
sideswiper's Avatar
I googled your tv and under the amazon ad it had this about your tv.The set's split-cabinet design allows the cabinet to be divided for ease of delivery and installation.
What's in the Box
TV, cabinet (which splits into 2 sections with lifting handles for easy delivery and installation), remote control, batteries, a user's manual, and warranty information
you can google your tv and read the whole ad if you like
sideswiper is offline
Reply Rear Projection Units
