Samsung Dlp interchangable lamps? - AVS Forum | Home Theater Discussions And Reviews
Old 08-10-2012, 11:46 AM - Thread Starter
Zeke1313's Avatar
I have a bp96-01472a lamp that sounds like it would work in my new Sammy hl61a650 that calls for the 01653a bulb. Can I use the 01472a in that set? On some websites it appears they are interchangeable. If that is the case, why the different #'s? Thanks
Zeke1313 is offline
