samsung hlr4264wx/xac: i get LAMP - timer - standby/temp lights on (no display) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-10-2012, 11:30 PM - Thread Starter
wantboost's Avatar
when i plug the tv in i get the LAMP light on the button on the front of the TV. (no display)
After a minute or 2 it says TIMER and standby/temp beside it???
wantboost is offline
post #2 of 5 Old 08-11-2012, 08:00 AM - Thread Starter
wantboost's Avatar
i pulled the bulb out and it IS burnt.
my concern is about the timer and standby/temp message. Is that a result of the LAMP being burnt???
thanks
post #3 of 5 Old 08-11-2012, 11:23 AM
Augerhandle's Avatar
Quoted: 859 Post(s)
Liked: 775
Page ten of your Owner's Manual.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #4 of 5 Old 08-11-2012, 05:55 PM - Thread Starter
wantboost's Avatar
i dont have one
post #5 of 5 Old 08-11-2012, 07:29 PM
Quoted: 859 Post(s)
Liked: 775
Originally Posted by wantboost View Post
i dont have one
http://lmgtfy.com/?q=samsung+hlr4264+manual
It says that all 3 lights will flash if you have a defective lamp. Replace the lamp and you should be good to go.
Reply Rear Projection Units
