replacing a dlp screen question - AVS Forum | Home Theater Discussions And Reviews
Old 08-14-2012, 11:48 AM - Thread Starter
mach_71's Avatar
hello i have a mitsubishi wd65733 with a cracked screen ... i am having a hard time finding one. i was curious if other 65" screens would work ... like ws65 rear projections ? or even other brands that are 65 "... thanks guys i really dont know much about this
mach_71 is offline
Old 08-14-2012, 03:26 PM
GEP
GEP's Avatar
No Screens from other brands or screens from other types (the WS models are CRT RPTV not DLP) will not work the Lenticular screen (the outside screen) needs to match the Fresnel Lens (the inside screen). The two are paired in optical properties.
Have you tried Mitsubishi Parts Department or a authorized service company or are you committed to DIY?
Mitsubsihi Parts is 1-800-553-7278
GEP is offline
Old 08-14-2012, 03:50 PM
stilwell's Avatar
I replaced the fresnel screen on my 82" and got the part from SearsPartsDirect, though I could have gotten it from Mitsubishi at the same price.
If you download the service manual for your model, page 48 has the parts number you need, though you will have to determine if you have a type A or type B. The manual shows you how, as well as dis-assembly and re-assembly instructions. Definitely doable, if you take your time and handle carefully (with gloves, so as not to leave fingermarks).
PART ID NUMBER TYPE
SCREEN -LENTICULAR 491P208X50 A
LENS-FRESNEL 491P206X40 A
SCREEN -LENTICULAR 491P207X70 B
LENS-FRESNEL 491P206X60 B
stilwell is offline
