Mitsubishi WD-65C9. Any good? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-19-2012, 05:02 PM - Thread Starter
gostillerz's Avatar
I've been looking to upgrade my garbage tv (Insignia 42" 1080p LCD). I was looking at 50-55" Panasonic UT or ST plasmas, but saw an ad on Craigslist for a WD-65C9 which he said was used sparingly and is selling because he got a front projector. Bulb is supossedly good. He asked $575, accepted $525 for the tv and matching stand. Good deal?
m
I don't have a ton of money, so obviously a 65 DLP for a lot less than a smaller plasma has me excited a bit. I looked up the model, 1080p, 3D, etc. Anyone have experience with this set and what I should look for when I check it out?
It's these cans! He hates these cans!
gostillerz is offline
post #2 of 2 Old 08-19-2012, 05:12 PM
yadfgp's Avatar
Quoted: 67 Post(s)
Liked: 68
That's a pretty good deal. So long as it's all in excellent condition.
I had bought a Mits I think of the same model year, but different model. At least I think it came out the same year. It was the WD-65736. These sets came out in 2008 I believe. More or less the same TV as the C9. I may be off by a year either way on these sets. But close enough irregardless. Considering you're getting the stand as well that's what makes it a pretty good deal in my book.
The only problem I'd have with buying that set, is that Mits has really come a long way in the last couple of years in the PQ department with their RPTV's.
I bought last years WD-73640, and I just have a tough time watching my older set, the PQ improvement is just substantial in my opinion.
If you do buy that set, make sure you don't look at any of the newer models.
That way you won't know what you're missing by going with the older TV. biggrin.gif
yadfgp is offline
Reply Rear Projection Units
Mitsubishi , Insignia , Panasonic Viera Tc P60ut50 Plasma Tv , Panasonic Viera Tc P65st50 Plasma Tv , Plasma Hdtv , Mitsubishi Wd 65c9 180 Watt Tv Lamp Replacement
