DLP bulb burning screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-25-2012, 10:53 PM - Thread Starter
kitatiger's Avatar
On Samsung HL50A650 DLP
I had a bulb replaced back in January and last month started to see what looks like a burn mark starting on the screen...see photo....
You can see the 2 verticle spots that seem like an "8" on the left, white against the black screen, brown against white....and it's getting worse....
ANY ideas on what this may be?
....I have geeksquad coming on Tues to troubleshoot (I'm in month 47 on the 48 month service contract)...and geekonthephone said I may have to be given a replacement...
If I have to, I prefer and will probably go plasma....
Any comments on this model.... PN51E550D....it seems to be okay....
I may be able to get this one too: PN50C7000....any thoughts on this one?
Samsung HL50A650
kitatiger is offline
post #2 of 6 Old 08-26-2012, 06:14 AM
videobruce's Avatar
Quoted: 597 Post(s)
Liked: 246
1. It's a lamp,
2. The "screen" can not be "burned",
3. I assume it is some kind of smudge on the optical path somewhere,
4. As far as the Plasma, you would have to ask it in the Plasma forum though I assume that is a Samsung and they are greater power hogs than Panny. wink.gif
But, what is the discolorization at the top of the screen pic on the right?
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #3 of 6 Old 08-27-2012, 12:26 AM
the Son's Avatar
Looks like the transparency of the Windows 7/IE9 title bar.
the Son is offline
post #4 of 6 Old 08-31-2012, 07:45 PM - Thread Starter
kitatiger's Avatar
Well....
Geeksquadguy came the other day
....after calling HIS tech support it was determined/hypothesized that the problem is with the DLP chip....which we are going to replace...
....and maybe it will be the cure-all....
But....when reading others' similar experiences, the probem was described as a loss of pixels...rather than the "smudge" I have on my screen....well we'll see....
...if the chip is not the solution then there's a new TV on the horizon...
An odd thing happened...when the techie went into and left the service menu after doing his diagnostics, all the settings reverted to factory default....and he said it shouldn't have...
...called tech support and they think my service guy probably clicked reset and didn't realize it...I hope so...
Samsung HL50A650
post #5 of 6 Old 09-01-2012, 04:38 AM
videobruce's Avatar
Quoted: 597 Post(s)
Liked: 246
IIRC, that is normal, settings are reset.
post #6 of 6 Old 09-07-2012, 07:45 PM - Thread Starter
kitatiger's Avatar
Well Geekman came yesterday and removed the offending chip and put in the new one and all is well...
The problem was that in some unexplained way the chip surface got smudged and the smudge showed up on the screen...
MY explanation was that a smurfette lizard got into the back of the set and took to the warm chip for a snooze...little bugger...
Geekman was happy to see that the TV's innerds were otherwize VERY VERY clean....
Here's hoping the TV can go another few years....
Samsung HL50A650
Reply Rear Projection Units
