picture thread for 80 and 90 inch displays setups. - AVS Forum | Home Theater Discussions And Reviews
Old 08-26-2012, 08:39 PM - Thread Starter
suncom3's Avatar
Do many of you have 80 or 90 inch mits displays in standard living room or den areas of the house. Id like to see some pictures of what these look like in most peoples setups
Im considering putting a 80 in a main room of a open concept kitchen living room...dont know if this thing is gonna look like a outa place monstrous..might be more of a dedicated theater room type display..
suncom3 is offline
Old 08-27-2012, 10:53 AM - Thread Starter
suncom3's Avatar
anyone?
suncom3 is offline
Old 08-27-2012, 11:40 AM
wlcohen's Avatar
I have mine wall mounted but no pictures yet.
I used painters tape to map it out on the wall before I bought it to make sure it would fit
wlcohen is offline
Old 08-28-2012, 12:08 AM - Thread Starter
suncom3's Avatar
wall mounted? well thats a new one...how did you do that with a dlp
suncom3 is offline
Old 08-28-2012, 12:28 PM - Thread Starter
suncom3's Avatar
this is my 67 sammy setup,from both perspectives,one from the couch at around 12ft and the other from the kitchen prospective at about 24ft away.
Uploaded with ImageShack.us
suncom3 is offline
Old 08-28-2012, 04:27 PM
g4s
g4s's Avatar
This is our 92840 setup in our living room. The wide angle lens is a little deceiving. The long distance shot is from 27'. The wall the TV is against is a little over 21'.
g4s is offline
Old 08-28-2012, 07:05 PM - Thread Starter
suncom3's Avatar
Nice looking setup,That art you have sets the room off nice,strange place for a fish tank,I use to have a salt water reef 75 gall tank and trying to keep it off the wall and have to clean all 4 sides would have been tough.
your 90 doesnt look that big in there at all,that high ceiling suits it very well..Its Hard to tell in pics though,My 67 looks small in the pics I posted but it looks huge in the room especially to people you are not use to large scale displays.
suncom3 is offline
Old 08-28-2012, 08:16 PM
g4s
g4s's Avatar
Thanks. Yeah, that tank doesn't look very big in the picture. It's a 120 gal. extra high. only 5' long. Fresh water, really low maintenance. It sits directly over a beam.
That's the 5th big TV that's been in that same spot over the last 20 years. Anyone we know is used to seeing a jumbotron sitting there. I know what you mean though. I'm sure some of our friends think it's too big, but not when it's movie time.
g4s is offline
