WS73837 as a monitor question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-31-2012, 03:46 PM - Thread Starter
shadowman1's Avatar
I'm trying to hook up my Mitsu WS73837 to my laptop with little success. I see from other posts on the forum that it can be done but need some info.
I have a 25' cable that has the 15 pin D-sub connector plugged into the laptop VGA output and it has component (RBG) leads plugged into the side inputs of the Television. The TV recognizes the input and goes into set up mode to name the input. I have the laptop set up for dual monitors but I get either a black screen or a blue (no signal) screen.
I have an HP and a Toshiba laptop and I get the same results with both.
I know there are VGA analog to digital converters on the market but other posts I've read on this forum don't mention any converters. I'm thinking the TV should be able to convert the signal but maybe I'm wrong.
Any ideas how I can get the display to show up?
Thanks in advance.
shadowman1 is offline
post #2 of 3 Old 08-31-2012, 03:53 PM
GEP
GEP's Avatar
Incompatible signal types. The signal type output for the 51-pin VGA is RGB and normally separate H and V sync. The input on the TV YPbPr which is luminance with color difference also known as Component Video. Simply not the same type of signals. If you laptops have Display Port out, you can get for rather low price Display Port > HDMI converters. You should also make sure you name the input PC on the TV in order to make sure it uses PC resolution and color space processing.
GEP is offline
post #3 of 3 Old 08-31-2012, 06:59 PM - Thread Starter
shadowman1's Avatar
Reply Rear Projection Units
Mitsubishi
