TV won't turn on after color wheel replacement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-31-2012, 03:18 PM - Thread Starter
DNAtester's Avatar
My color wheel broke on my HLR5067w while I was watching it. Since I witnessed it, I figured the diagnosis and repair was going to be fairly easy. I put the new color wheel in, put everything back together and the set won't turn on. The fans run and the "Lamp" indicator flashes. The lamp does not try to fire, and I don't here the color wheel whirl. I though I broke the lamp or something, so I replaced that. I checked and rechecked orientation of wires, kill switch, etc.
Does any key have any thoughts?
I am about to see what a shotgun does to a DLP. Been working on it for hours on my day off!
DNAtester is offline
Reply Rear Projection Units
