Can you reset toshiba service menu? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-05-2012, 02:17 AM - Thread Starter
ogxbmc's Avatar
I messed up my Toshibas picture and various other settings in the s/m:eek:, is there anyone who has a tsb-h84s and knows how to reset it? im desperate and am willing to try someone else's settings even if they dont have the tac 472 body...i am a noob so please take it easy because i didnt write down the original values, im still able to use the tv though.
ogxbmc is offline
post #2 of 5 Old 09-05-2012, 11:38 AM
GEP
GEP's Avatar
This is the problem with entering the service menus; often changes you make there are permanent and there is no reset. Also the original settings are often individual to the TV (adjusted to the natural variation in parts) so someone else’s settings would only be ball park at best.
Keep in mind that no manufacturer will tell consumers to enter service menus and make adjustments. As far a the manufacturer is concerned, that is the same thing as adjusting the old manual controls inside the TV, not intended for consumers.
ogxbmc likes this.
GEP is offline
post #3 of 5 Old 09-05-2012, 02:20 PM - Thread Starter
ogxbmc's Avatar
I just want the screen to fit, convergence is fine though...
ogxbmc is offline
post #4 of 5 Old 09-06-2012, 04:32 AM - Thread Starter
ogxbmc's Avatar
update...
Screen is Almost there!!!!
(hourglass shape)
ogxbmc is offline
post #5 of 5 Old 09-06-2012, 04:52 AM - Thread Starter
ogxbmc's Avatar
Can someone tell me what each setting does? I actualy improved picture but the shape at at the bottom.
ogxbmc is offline
Reply Rear Projection Units
