Mitsubishi WD 73640 Time Warner remote issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-07-2012, 11:19 AM - Thread Starter
Lbigt1's Avatar
I have a 73 Mitsubishi WD 73640 T.V. and I recently switched to Time Warner cable. The remote that comes with the cable box is not working when I try to change video source. Everything else(vol,changing channels..etc) on the remote works. Thanks in advance for any help.
Lbigt1 is offline
post #2 of 2 Old 09-07-2012, 02:42 PM
GEP
GEP's Avatar
You need to program the remote for your TV. Channel changing is done by the cable box not the TV so that does not prove the cable box remote is programmed for the TV. In some cases the same is true for volume.
If the remote properly turns on or off the TV, that is an indication the remote is programmed for the TV. For other functions, you have to press TV at the top of the cable box remote, if the CABLE light is flashing when the remote keys are pressed, then you are sending instructions to the cable box, not the TV.
Since Time Warner uses several remotes, you may need to go to the Time Warner web site or store to get instructions on how to program your remote for your brand of TV.
GEP is offline
Reply Rear Projection Units
