HL67A750 Black line at the bottom, no shadow, just a black line about 1 inch missing, - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-08-2012, 08:18 PM - Thread Starter
XCALIBURPCS's Avatar
Hi, I bought this tv for a $100 after checking everything the powersupply was bad, well i got the set to come on, now i see that im missing about an inch from the bottom, like if its not aligned properly, i will be changing the dlp chip on this tv as it has the white dots, I dont want to change the chip if the tv is going to be missing 1 inch from the bottom. what can i do?
XCALIBURPCS is offline
post #2 of 3 Old 09-09-2012, 08:02 PM - Thread Starter
ALRIGHT AND UPDATE TO MY PROBLEM, IT SEEMS LIKE THE LAST OWNER SWITCHED THE DLP CHIP WITH A BAD ONE, IN THE PROCESS HE DIDNT ALIGN THE DMD BOARD RIGHT CAUSING IT TO BE COME OFF CENTER, I MOVED THE DMD UP AND BOOYA, CENTERED, NOW I CAN ORDER THE DLP CHIP
post #3 of 3 Old 05-04-2014, 11:38 AM
andyseous's Avatar
I need help as well so what am I suppose suppose to align? What does it look like I too replaced the chip but I'm missing a bit from the bottom do I need to adjust the chip?
andyseous is offline
Reply Rear Projection Units
Samsung , Displays
