Sony SXRD Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-08-2012, 11:54 AM - Thread Starter
AAGraves23's Avatar
First post here!!! I just installed a rebuilt light engine for a KDS60A2000, which had a failing blue sxrd panel resulting in the green blob. After install I noticed the picture had a lot of blue. Especially in the darker areas. Changing the settings in the tv menu helped a little, but there is still too much blue. Does anyone know of a setting in the service menu that may help? Like a brightness/contrast setting or red green blue levels?
Thanks for the help.
AAGraves23 is offline
post #2 of 2 Old 10-08-2012, 01:32 PM
KewlK's Avatar
The blue bias is obviously way too high. There are more aggressive bias and gain controls within the service menu vs the user menu ramps.
Your set needs to be completely recalibrated. Be wary of having a go at it yourself, you'll never get things right without proper equipment/experience.
I'd offer to calibrate your set if you were local, but highly doubt it.
Good luck.
KewlK is offline
Reply Rear Projection Units
