Sony plasma SXRD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-15-2012, 10:36 AM - Thread Starter
hencpc836's Avatar
I have an eight year plasma Sony 50" TV. The picture is not as bright as it use to be. The picture is dim. I have adjusted the brightness setting as high as I can and still is not very bright. Is there a simple, inexpensive way to fix it or am I better of buying a new TV?
hencpc836 is offline
post #2 of 2 Old 10-17-2012, 09:29 AM
KewlK's Avatar
Hi, your TV is not a Plasma. It is a Liquid Crystal on Silicon rear projector.
You need to replace the lamp assembly (XL-5100). Extremely simple to do, it is extensively covered within the owner's manual.
It is possible to save a few dollars by reusing the old assembly and replacing just the bulb. However, I recommend you purchase a new XL-5100.
Surprised that you are experiencing a dim lamp for the first time. They typically burn out within 6000 to 8000 hours.
KewlK is offline
Reply Rear Projection Units
