Mitsubishi 2007 DLP vs 2012 DLP: still geometry issues? Better PQ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-06-2012, 04:38 AM - Thread Starter
bearcat2002's Avatar
Quoted: 47 Post(s)
Looking to upgrade my 73833 to something at least the same size or bigger...although its difficult to find. As far as I know, my only options are another DLP, Sharp 80", or Samsung 75". The Sammy is $10k so can't swing that. The sharp is doable around $4000 but slightly worried about quality and Sharps financials. So as always the Mits DLP gets you best bang for the buck, but my biggest complaints on my 07 73" was geometry... Significant amount of pincushion that was best corrected by an isf guy but still there and still annoying. Does anyone know if geometry issues are better with the 2012 73s and 82s? Also I'm wondering if there have been improvements in picture quality over those 5 years. One would think. Also, it sounds like the sound bar built into the new Mits diamonds sound pretty good as well, but geometry and picture quality really are my main concerns on the new 73s and 82s. Thanks in advance.
bearcat2002 is offline
post #2 of 2 Old 11-06-2012, 08:51 AM
sodaboy581's Avatar
Quoted: 27 Post(s)
Liked: 39
There's still geometry issues on the new TVs as well. I have a WD-72642 and was able to correct most of it pretty decently.
I've still got some minor issues in the extreme upper left, extreme upper right, extreme lower left middle, and extreme lower right middle, but it's all very much acceptable and I'm able to use it with my HTPC just fine without being annoyed...
Can't say anything about the picture quality vs the old ones, but I'd assume it'd have been improved with new chips and all.
What I can say is the picture quality of my 72642 is pretty awesome. No complaints at all.
Sony XBR-65X900E, Denon AVR-X2300W, Polk CS20 Center, Polk Monitor 75T Fronts, Polk TSI300 Rears, Power Sound Audio S1500 Subwoofer.
sodaboy581 is offline
Reply Rear Projection Units
