Discharging the CRT's in a rear projection unit - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-08-2012, 04:08 PM - Thread Starter
llmercll's Avatar
Hello!
I'm disassembling a rear projection tv from the 90's and am wondering how to go about discharging the 3 crts. Do I just ground one, then another, and the last one? And remove the anode plug?
I'm also curious how the voltage would compare to a single crt screen. Would it be more since there are 3? or less because each one is much smaller.
thanks!
llmercll is offline
post #2 of 4 Old 11-08-2012, 05:29 PM
taichi4's Avatar
Quoted: 322 Post(s)
Liked: 153
Post your question here:
Don't dump your CRT RPTV!
It's only a few threads down on this page.
taichi4 is offline
post #3 of 4 Old 11-10-2012, 03:29 PM - Thread Starter
llmercll's Avatar
Haven't gotten any replies =/
Can anyone with some knowledge on the subject chime in? Don't want to get shocked =p
I'd really appreciate it =)
thanks!
llmercll is offline
post #4 of 4 Old 11-12-2012, 06:39 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
The voltages are the same. Use the "standard procedure" for discharging a CRT... (hint: search).
budwich is offline
Reply Rear Projection Units
