Pioneer elite 720hd needs repair - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-14-2012, 09:14 PM - Thread Starter
buster brown's Avatar
Red gun will not converge and tv needs calibration.
I live in Oregon and want to get my unit fixed. I don't want to throw it away.
I am serious about paying for repairs.
Please contact me by email - sdi@machmedia.net
Thanks for reply.
Dale Brown
Hermiston, OR
The last 48 yrs. are a blur
buster brown is offline
post #2 of 4 Old 11-14-2012, 11:50 PM
jgruessing68's Avatar
Check with Mr. Bob... here on the forum or...
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
bob at imageperfection dot com
www.imageperfection.com
YouTube channel: mrbobbigscreen
He can help you guaranteed.
Good luck!
Joe
jgruessing68 is offline
post #3 of 4 Old 11-15-2012, 09:39 AM - Thread Starter
Thank you!
post #4 of 4 Old 11-15-2012, 06:00 PM
tpaxadpom's Avatar
Quoted: 48 Post(s)
Liked: 33
Should be an easy fix if you know how to solder. I would have helped fix it but you are 3 hours away from me.
Bob can definitely fix it. You just need to replace the IC's. If you need service manual PM me.
tpaxadpom is offline
Reply Rear Projection Units
