Mitsubishi Service Centers replacing bulbs only - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-19-2012, 11:50 AM - Thread Starter
AnthonyB's Avatar
Today, on my quest to find a bulb for my dlp, I called several Mits service centers locally because I want the lamp now.
Almost all the service centers I called replace the bulb within the housing.
I asked "how long does that housing last" and they all explain that unless it melts basically forever.
AnthonyB is offline
post #2 of 3 Old 11-19-2012, 08:37 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
It basically can last forever but it can crack, get brittle and collect dust, it's plastic. They're probably not OEM lamps. The benefit of a new housing is, it's new, ease of installation and you don't touch the lamp.
If I needed or wanted a lamp ASAP I would have no problem using the old housing. If Mits has your lamp it doesn't take long to get, I get mine in 2 days.
colour is offline
post #3 of 3 Old 11-19-2012, 10:08 PM - Thread Starter
AnthonyB's Avatar
They are replacing with osram bulbs
AnthonyB is offline
Reply Rear Projection Units
