Double Image or 'color ghost' images on JVC HD-52Z575 / HD-52Z585 / HD-61Z575 / HD-61Z585 Televisions - AVS Forum | Home Theater Discussions And Reviews
Old 12-05-2012, 10:48 PM - Thread Starter
Ryan Langstaff's Avatar
Do you have a colored ghost image on your tv screen? Almost like a (bad) 3D effect?
DO NOT THROW OUT YOUR JVC TV!!! I almost made this mistake by reading 'help' forums where everyone was saying you have a bad convergence drive. I actually bought a replacement tv until I stumbled onto the solution, so glad I hadnt tossed my old tv yet.
The solution is an easy fix. Ignore anyone telling you to take it to a service center or to replace the convergence driver. You need to access the service menu on your television by using your remote control:
DRIVE CONVERGENCE Adjustment (Using remote control)
•Use the inner RGB box pattern.
(1)Set the [SLEEP TIMER] key to 0 min.
(2)Press the [DISPLAY] key and thekey simultaneously.
(3)Press the [9] key to display the RGB box pattern.
(4)Select the R mode by pressing the [DISPLAY] key.
(5)Adjust the R mode to setting as same as G mode bypressing the [CH ]+ / [CH -] key.
(6)Select the B mode pressing by the [DISPLAY] key.
(7)Adjust the B mode to setting as same as G mode bypressing the [VOL] - / [VOL +] key.
(8)Check to see that the cross pattern is white. If thecross pattern is not white, readjust (5) to (6).
That's it, your color is now corrected.
This isn't your problem? Here's a link for a full service manual.
http://www.scribd.com/doc/96053806/HD52Z575
Ryan Langstaff is offline
Old 01-29-2013, 06:32 AM
cindysims61's Avatar
I'm trying to use your problem fix but I think you left out a word! At the very beginning... hold down the [display] key and the [?] key.
Please help! I'm losing my eyesight and my mind trying to fix this!
Thank you!
cindysims61 is offline
Old 03-04-2013, 05:32 AM
carla124's Avatar
Did you find out which key to hold down with the display key in step 2?? Please help thank you
carla124 is offline
