Standard definition problem with Toshiba 56HM195 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-17-2012, 01:18 PM - Thread Starter
nper7's Avatar
I was recently given a Toshiba 56HM195 by family friends. It worked just fine for them when connected to an HD cable box, but when connected to a standard cable box, picture quality gets scrambled. The box Im using just has an coaxial input from the wall to the box, and an output from the box to the tv. There is no component output or HDMI output from the box. I'm wondering if there is any fix to this problem. Thank you!
nper7 is offline
post #2 of 2 Old 12-30-2012, 08:49 AM
pacofortacos's Avatar
Liked: 24
Did you try connecting it to a different input?
Did you try just the coax from wall to tv?
pacofortacos is offline
Reply Rear Projection Units
