wd73742 audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-20-2012, 06:26 AM - Thread Starter
Timman123's Avatar
Hello, just received my new 73", love the picture but...I have noticed the audio is out of sync with the video. Seems to be worse with the level sound on so I turned it off. There is still some delay. Do you believe that this is a fault of the tv(bad) or just a genral design of the tv itself? I use all HDMI and this seems to effect all inputs. I have not tried game mode for fear that I do not have all of the necessary video adjustments I like on normal v ideo. Any help or input would be gre:)atly appreciated. Thanks.
Timman123 is offline
post #2 of 8 Old 12-29-2012, 03:04 AM
videobruce's Avatar
Quoted: 601 Post(s)
Liked: 246
Is this using the internal audio (speakers) or a external sound system (receiver)?
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #3 of 8 Old 12-31-2012, 02:18 PM - Thread Starter
Timman123's Avatar
Tv speakers, does not seem to be effected on other inputs. It could be satellite and i am not used to seeing it so big...?
post #4 of 8 Old 01-01-2013, 06:27 AM
videobruce's Avatar
Quoted: 601 Post(s)
Liked: 246
I didn't ask and you didn't state what your source was.
First off, how is the audio with the internal tuner? You have tried the OTA tuner haven't you?
Second, how is the audio with a outboard audio system? Of course, you do have a audio system, don't you?
post #5 of 8 Old 01-02-2013, 11:10 AM - Thread Starter
Timman123's Avatar
Main source is satellite. I do have an ant but it is fed through the satellite ota input. I have noticed that it seems the worst on ota input although it feeds throught the satellite. I have a dish 922 receiver. I did use a Bose stereo system while playing mvies and such through a media streamer(sound seems to match) although it did not seem to at first. It is like the problem comes and goes. I hadc a wd65637 in the same place and did not notice the problem. I have not tried new hdmi but I find that possibility remote that the cable is the problem.
post #6 of 8 Old 01-04-2013, 08:25 AM - Thread Starter
Timman123's Avatar
videobruce, you think the tv is defective or should I change out my sat receiver? Thanks,
post #7 of 8 Old 01-04-2013, 08:34 AM
videobruce's Avatar
Quoted: 601 Post(s)
Liked: 246
1. Try the internal tuner directly from your antenna through the internal speakers, then your sound system,
2. If ok, how about another device on another input? DVD player? To internal audio, then your sound system. You stated this was ok?
3. Have you run the audio directly into your sound system from your STB?
4. Narrow it down to one item.
post #8 of 8 Old 01-04-2013, 10:53 PM - Thread Starter
Timman123's Avatar
Yes, only the satellite. Now I wonder, should I replace sat rec or will the problem always be there? Thanks for your help.
Reply Rear Projection Units
