Toshiba 52hm84 lamp problem - AVS Forum | Home Theater Discussions And Reviews
Old 12-30-2012, 03:33 PM - Thread Starter
Tipit008's Avatar
My Toshiba DLP RPTV blew a lamp. I put in a new one that came on, worked for a few days, then nothing. I took it out, dusted the contacts and put it back in. Most times it didn't work, but about 1 out of 5 times, it did... but then did not come back on again when I tried it.
I had another one on order and put it in, but this one doesn't light up either.
The fan near the lamp does comes on. Any one have this same problem ? I love this TV and would like to keep it.
Any chance there is a defect in the circuit that powers the lamp. I saw "inards" instructions for other brands of RPTVs here, but not for Toshibas...???
Anyone know where I can get some info / suggestions ??
Marc P.
Tipit008 is offline
Old 12-31-2012, 08:22 PM
ChuckF.'s Avatar
Marc P.
Start by searching the internet for a service manual that will have a basic troubleshooting flowchart. Should be able to get one for free if you look long enough.
ChuckF. is offline
Old 12-31-2012, 09:37 PM - Thread Starter
Tipit008's Avatar
Thanks for the idea. With the pattern I'm getting on the front LED lights, the manual simply states that "the lamp doesn't work". Only problem is... is that the lamp does work. As stated, it came on a few times and I've now put in a brand new one.
Basically, the TV tells me the lamp isn't good, but I know it to be good...
The manual doesn't go any further. Any suggestions for the next step appreciated.
Marc P.
Tipit008 is offline
Old 01-01-2013, 09:24 AM
pacofortacos's Avatar
Liked: 24
Is it a Toshiba lamp or aftermarket? The Toshiba's are picky on lamps.
Other main possiblility is the ballast board, there are threads on here on repairing them.
pacofortacos is offline
Old 01-01-2013, 09:27 AM - Thread Starter
Tipit008's Avatar
One is, one isn't.
I don't know what the "ballast" board is, but I'll do some research.
Marc
Tipit008 is offline
Toshiba 52hm84 120 Watt Tv Lamp Replacement
