Please Help with WD-73842 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-04-2013, 04:42 PM - Thread Starter
Hennessy1's Avatar
Just got a new DLP trying to put it in a friends house. Door way is a little smaller than he thought. Is there a way I can take off the rear cabinet to just reduce the size or even the front screen?
Hennessy1 is offline
post #2 of 9 Old 01-04-2013, 09:39 PM
pacofortacos's Avatar
Liked: 24
rear cabinet = no
front screen, you can take it off but it isn't very thick - probably gain maybe 1/2" or so.
Maybe stand it on it's side to get it in. JUST BE CAREFUL the back of the tv is one big mirror and $$$$.
pacofortacos is offline
post #3 of 9 Old 01-04-2013, 09:49 PM
Augerhandle's Avatar
Quoted: 748 Post(s)
Liked: 649
The TV is only 18 inches deep. What kind of door are you trying to get through?
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #4 of 9 Old 01-05-2013, 05:27 AM - Thread Starter
Hennessy1's Avatar
I did not know that you could stand it on it's side. There's no issues with doing that? the doorway is wide enough it's just the angle at which we need to get it through is tough.
post #5 of 9 Old 01-05-2013, 09:42 AM - Thread Starter
Hennessy1's Avatar
If you say its ok to turn on the side Ill do that. Is there anything we shoild be cautious of?
post #6 of 9 Old 01-05-2013, 06:17 PM
Liked: 24
Just be careful with it. The back of the tv is one BIG mirror just inside the plastic. And the front screen is not real strong.
Maybe get a moving dolly from harbor freight and set it on it gently on it's side and wheel it in the room - if uncarpeted.
That way you aren't holding it.
They really aren't "that" fragile but you can break them.
With two people you should be able to turn it on it's side to get through the door. Just be careful and try to just turn it slowly.
post #7 of 9 Old 01-05-2013, 06:19 PM
Liked: 24
Is it still in the box?? If so, removing the box will gain space, or in the box will add support for turning it.
post #8 of 9 Old 01-06-2013, 05:31 AM - Thread Starter
Hennessy1's Avatar
Ok so we were able to turn it on it's side onto a few blankets. Got it moved in and everything turned on ok and picture still seems good as well. Thank you all very much for your help I really appreciate it.
post #9 of 9 Old 01-06-2013, 10:17 AM
Liked: 24
Reply Rear Projection Units
