Mitsubishi 73733 - Horizontal lines where bright objects are - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-11-2013, 07:37 PM - Thread Starter
cameronjpu's Avatar
So I just replaced the bulb in this unit because it had become very dim. After doing so, now I notice these horizontal lines that go across the screen wherever bright yellow/red objects seem to be. It's very noticeable, not hard to see at all even in relatively bright scenes. I have attached an image.
I figured it must have been the bulb, so I returned it and bought another, but the same thing is happening. So I assume the problem was actually hidden when the bulb was dying. Is this something that can be fixed easily, and what part needs to be replaced?
Thanks! 2013-01-06 22.28.18.jpg 2125k .jpg file
Name:	2013-01-06 22.28.18.jpg
cameronjpu is offline
post #2 of 4 Old 01-11-2013, 08:10 PM
hery19's Avatar
Quoted: 26 Post(s)
I had the same issue, just resolved it by switching my dvr from component to hdmi. Also does your tv take long to power on?
TV:Mitsubishi WD 73833, Receiver:Anthem MRX 720, Bluray: OPPO BDP-93, Conditioner:Panamax M4300-PM, Speakers:B&W CM4 Fronts, CMC center, CM2 Surrounds, Sub: SVS PB1-ISD & Remote:Harmony One
hery19 is offline
post #3 of 4 Old 01-11-2013, 08:49 PM - Thread Starter
cameronjpu's Avatar
Ugh.... you have to be kidding me. I bought this stupid Vulkano and had to switch to component to use it. Now it turns out that it caused this problem. The thing sucked anyway! Terrible interface! Ugh! Thanks for the help, that fixed it!
post #4 of 4 Old 01-11-2013, 09:01 PM
hery19's Avatar
Quoted: 26 Post(s)
Glad I could help! The net is a great tool!
hery19 is offline
Reply Rear Projection Units
