2010 Mitsubishi WD-73738 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-16-2013, 07:00 AM - Thread Starter
shanedog07's Avatar
I have a question on the 3D capabilites of this set...I have been using shutter glasses for the past 2 years but is there any way I can watch the 3D movies without the shutter glasses as in movie theatre glasses, passive glassware or can this TV only do shutter? I just ask this becuase at times I can have issues with how the shutter glasses work and well the battery life can sometimes suck.
For example can the below glasses be used?
http://www.buy.com/prod/pair-of-universal-3d-passive-glasses-work-with-passive-3d-televisions/234088868.html?listingId=227884214
Thanks in advance!
shanedog07 is offline
post #2 of 5 Old 01-16-2013, 09:23 AM
lparsons21's Avatar
Quoted: 55 Post(s)
Liked: 25
Simple answer is no. Different technology that is not compatible.
Lloyd
lparsons21 is online now
post #3 of 5 Old 01-16-2013, 12:11 PM
Augerhandle's Avatar
Quoted: 748 Post(s)
Liked: 649
There are different Shutter glasses available. Shop around.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #4 of 5 Old 01-16-2013, 12:22 PM - Thread Starter
shanedog07's Avatar
Any shutter glasses you all recommend? Bc I have bought a few different ones and had issues
post #5 of 5 Old 01-16-2013, 12:38 PM
Quoted: 748 Post(s)
Liked: 649
Look through the forums. There are several threads discussing brands. I prefer Xpand, but that's just 1 opinion.
Reply Rear Projection Units
