Who has this Innovex TPT83G29 83" tv stand ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-16-2013, 09:06 PM - Thread Starter
Jetmeck's Avatar
Quoted: 26 Post(s)
Well made ?
Exact distance between shelves ? Please include with and w/o the metal support bar.
Getting conflicting info on specs.
Here is a link. http://www.zoostores.com/shop/innovex-innovex-glass-tv-stand-tpt83g29-tv-stand.html
Bill
Jetmeck is offline
post #2 of 3 Old 05-08-2013, 07:39 AM
rjruby's Avatar
Quoted: 18 Post(s)
003.JPG 1840k .JPG file
I installed this stand recently for my new 80" Sharp TV. See attached photo.
Distance between shelf and bottom of support bar is 7 1/8".
Distance between shelves is 8 1/2".
I needed a stand to accomodate my Definitive Technology SSA-50 soundbar and support the weight of the TV.
It fits my needs perfectly and is well made.
I hope this helps you.
rjruby is offline
post #3 of 3 Old 05-08-2013, 07:46 AM
rjruby's Avatar
Quoted: 18 Post(s)
Also, the manufacturer told me the top shelf will support 190 lbs.
rjruby is offline
Reply Rear Projection Units
