Any suggestions for crossover settings? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-18-2013, 03:51 PM - Thread Starter
DGBarnes's Avatar
I just ordered a WD-73842 from Paul's which will be delivered next week. I'm putting it on a corner TV stand and plan on putting a subwoofer behind it on the floor. I know the Mits has a level control for subwoofer volume, but I didn't see anything about crossover. And after scouring the docs on Mitsubishi's web site I've about given up on finding the frequency range on the built-in 16-speaker system. Does anyone have any suggestions on where to set the crossover on the subwoofer? I realize it would be best to tinker with it some, but after installation, it's going to be a bear to get to!
Thanks in advance!
DGBarnes is offline
Reply Rear Projection Units
