WD-65C9 error code 61 no picture blinking red light - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 02-17-2014, 05:22 PM
Jaylo54's Avatar
That is good advice about the bulb.  THANKS!
Jaylo54 is offline
post #32 of 32 Old 04-27-2014, 06:18 AM
Jaylo54's Avatar
I did go ahead and put the new bulb in and will be using the old one as a back-up.  I never did do the software update.  Do you think there is any reason to do it? I basically just watch TV on this set.  I don't do any Netflex or stuff like that.
Jaylo54 is offline
Reply Rear Projection Units
Mitsubishi Wd 65c9 180 Watt Tv Lamp Replacement
