DLP mirror cleaning - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-22-2013, 03:01 PM - Thread Starter
AnthonyB's Avatar
I got my 82" used and apparently the old owners had the screen off to clean the mirror.
They did a piss-poor job at cleaning the mirror and there seems to be some smudging on it.
I discovered this after seeing a cobweb in the center on the screen through the ports.
Shortly after I discovered the cobwebs, the screen fogged up pretty bad between the Fresnel and lenticular screen when I left windows open on a cold and humid day with the weather in Florida on a cooling trend last week.
This weekend I'm going to take this project on myself. I know the basics of the project like using Monster screen cleaner and a microfiber cloth and have the manual to tell me how to get the screen off.
Should I spray the mirror if it is bad or just spray the cloth?
Which direction do I wipe? (With what motion)
Should I take the screen apart and clean between the lenses? Fog adheres to dirt
AnthonyB is offline
post #2 of 12 Old 02-23-2013, 11:42 AM
mrbrian200's Avatar
Ive had the great results cleaning the mirrors on these TVs using the following directions.  http://www.arksky.org/asoclean.htm   I don't follow it to the letter...  The solution seems to work fine without the drop of kodak solution and plain cotton rounds from the store (these do leave some lint, however a vacuum hose held about 1" above mirror picks it all up).   I'm sure it works better with the kodak solution but lacking a local supply I mixed it without and had good results.  If you'd rather buy solution I recommend Purosol.  It's easy to overlook in the directions, but I've found the air relative humidity being less than 60% to be the most critical factor regardless of cleaning solution used.   In high humidity a ghostly film is left behind no matter what you do.    Mist the cloth lightly, not the mirror.  Spraying the mirror I found gets everything too wet and the dirt/film just smears around instead of picking up.   I don't know about cleaning between the lenticular and fresnel... on 3 sets I have those two are clung together with static nothing has ever gotten in between.  Pulling them apart anywhere but in a clean room may be more trouble than it's worth.  I had one 5676 they started to separate along the top bezel (you could see it when the set was off) I tore the set apart and applied strips of gorilla tape around the edge to keep them stuck together.
mrbrian200 is offline
post #3 of 12 Old 02-24-2013, 07:32 AM - Thread Starter
AnthonyB's Avatar
5 hour job. Thanks for the advice. Got it clean and found that there was a lot of tobacco residue on the Fresnel lens and mirror but didn't need to take the screen apart to do that.
People really shouldn't smoke in home. What a nightmare cleaning that mirror was. I had to use 24 pads and 2 boxes of tissue..
The trick is to get the mirror clean and if it isn't clean the streaks won't wipe off with the tissue. Constantly changing tissue is extremely important. And those mirrors aren't half as fragile as I thought them to be. What a pain though. Of course this was a mirror for an 82" and it was huge.
I learned the screen is the size of a queen bed lol
AnthonyB is offline
post #4 of 12 Old 02-24-2013, 03:45 PM
mrbrian200's Avatar
Oh Gosh tobacco residue on the fresnel sounds like a nighmare.  I bet it did take 5 hours!   I do not envy you LOL.   ...But these sets do look like a million bucks when clean/proper/good bulb its still worth the effort.
post #5 of 12 Old 02-24-2013, 04:10 PM - Thread Starter
AnthonyB's Avatar
I will never be a fan of LCD/LED.. AMOLED is great if they can pack the pixels tight enough. I cringe every time I walk through a Walmart and see those displays.
Wouldn't buy a TV there anyway but they always have big pixels and the dot pitch is outstandingly bad.
Hope my 82 will stick around for a while. After this, I'm going projection.
AnthonyB is offline
post #6 of 12 Old 01-05-2014, 12:16 PM
IronHorse's Avatar
Found this thread and was hoping there were some pix of Anthony's cleaning process. I'm about to attempt a preliminary cleaning of my WD65737 and replacement of my bulb. First thing I guess is to look into the ports with my streamlight to see how much dust is on the mirror. BTW, those of you who have had these sets apart... are the mirrors plexiglass or real glass mirrors? Just curious.
I have a very fine short-handled trim brush that is super soft, never been used... so I'm thinking I'll "dust" the mirror from the side ports if I can reach all points. Then again... maybe I should pull the front screen off and try to do a more thorough cleaning. I'm not about to separate the layered lenticular screen... I'm not a smoker and I'm the original owner so I think a simple wipe down with a warm, damp microfiber should be sufficient on the screen back. The mirror, well, I don't know about the telescope formula but I'll look at it again.
What I'm wondering about is the lamp assembly and the lens. What to use on the lens if anything?
• If God had intended man to watch TV 24/7, he would have given him Rabbit Ears •
Mitsubishi WD-65737 DLP • Yamaha HTR-5063 • Panasonic BDT210 BDPlayer • DirecTVDVR • Chromecast • AppleTV/XMBC • Comcast HD
Speakers • Towers Polk Audio Monitor60B II • CC Polk Audio CS1B II • Rear Surround Klipsch S10s • Sub Velodyne EQ Max 8"
IronHorse is offline
post #7 of 12 Old 01-05-2014, 02:33 PM
taichi4's Avatar
Quoted: 322 Post(s)
Liked: 153
Over on the Don't Dump Your CRT RPTV thread, where retro CRT Reae Projection is king, the forum starter, Mr. Bob has posted much useful information about cleaning mirrors and lenses, which would apply to DLP as well.
Don't rush into cleaning before you read the relevant posts. You'd be surprised how easy it is to permanently scratch those delicate surfaces and coatings, which are responsible for a greatly magnified image. Scratches, even if unnoticed by your eye, will degrade the picture.
Mr. Bob loves CRT, but he is a highly skilled technician who works with all display devices.
taichi4 is offline
post #8 of 12 Old 01-06-2014, 11:49 AM
IronHorse's Avatar
I jumped into the lamp changeover and basic cleaning yesterday. Amazing results... if you want to see the dirty pictures LOL... go tho this post:
Cleaning/Lamp Change - Mitsubishi WD65737
post #9 of 12 Old 08-17-2014, 11:37 AM
Liked: 0
Wd 60737
I've got a Mitsubishi 60" WD 60737, at the bottom of the screen there is light image of a (picture this) dust huricane, when the picture is light with no color present, I tried dusting, no chemicals, anyone have this problem?
blackhillsrider is offline
post #10 of 12 Old 08-19-2014, 05:19 AM
Liked: 0
I've got a Mitsubishi 60" WD 60737, at the bottom of the screen there is light image of a (picture this) dust huricane, when the picture is light with no color present, I tried dusting, no chemicals, anyone have this problem? Any Qlue's ??????????????????? Thanks and God Bless
post #11 of 12 Old 08-19-2014, 06:33 PM
Arklier's Avatar
It's probably dust specks on one of the components in the light path. Possibilities include dust on the DLP chip, the lenses or the back end of the light tunnel. The lamp and front end of the light tunnel supposedly get hot enough that the dust will burn off. How defined are the edges?
A few days ago a dust speck showed up almost dead center on my Samsung HL-R5078W. It's about 2" across and only shows up on white or light-colored backgrounds. I'll probably end up taking it apart and vacuuming out the guts.
One thing to remember if you try to clean it out yourself: Don't use canned air. It will just blow around more dust and you might cause an even bigger problem.
"Give a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life."
Arklier is offline
post #12 of 12 Old 08-27-2014, 12:07 PM
lrizzo2001's Avatar
I have a similar problem on my Sony Grand Wega 60". It was in storage and has housefly crap on the lenses or someplace that is reflecting it onto the screen. Anybody have any idea where I can find instructions on removing the front or rear so I can
get to the parts that need to be cleaned?
lrizzo2001 is offline
Reply Rear Projection Units
