Can someone give me the remote keys to display the lamp hours on a Mits 73833? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-06-2013, 03:15 PM - Thread Starter
Floydster's Avatar
I am about to install a new bulb, as the old one is becoming yellow and darker. I remember that there was a key entry sequence on the remote to display the hours on a particular bulb, but that info has long since been lost. Also, is there a way to zero the counter when installing the bulb?
Thanks for any help.
Floyd
A lie can travel halfway around the world before the truth gets its shoes on. -- Mark Twain
Floydster is offline
post #2 of 4 Old 03-06-2013, 11:21 PM - Thread Starter
Floydster's Avatar
Can anyone with a similar (73") Mits give me the keys to get the lamp life?
post #3 of 4 Old 03-07-2013, 04:04 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
If you mean set hours since it doesn't keep lamp hours, it should be press MENU then 2-4-7-0.
colour is offline
post #4 of 4 Old 03-07-2013, 04:13 PM - Thread Starter
Floydster's Avatar
Thank you very much. I would like to keep track of how long this bulb lasts.
Floyd
Reply Rear Projection Units
