Samsung HLR 6167 Purple static - AVS Forum
post #1 of 3 Old 05-02-2013, 11:49 AM - Thread Starter
Screw Loos's Avatar
not sure if'm describing this corretly. However i have an old samsung DLP which i have put blood sweat and tears into over the past 3 years
replaced the dmd board (twice due to first one being faulty)
just recently (2 months ago) replaced the bulb with a philips brand.
am now seeing random purplish "static" in various areas on the screen.
Mostly when playing xbox on component in areas which should be white
I am thinking its the color wheel. I had the brightness set pretty high
(at request of wife) turned it down and the purple static is gone
any suggestions?
Screw Loos is offline
post #2 of 3 Old 05-02-2013, 11:53 AM - Thread Starter
Screw Loos's Avatar
http://youtu.be/31WMWZlyxp8
here is a video of the issue when it happens
post #3 of 3 Old 05-11-2013, 09:22 PM - Thread Starter
Screw Loos's Avatar
OK so i purchased a refurbished light engine.
worked for 2 days
then it started happening again http://www.youtube.com/watch?v=SkrW7N_ec1o
any thoughts
Reply Rear Projection Units
User Tag List
