Black pixel on Samsung HL67A750 DLP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-13-2013, 12:44 PM - Thread Starter
Howard - AVS's Avatar
Hello everyone. I'm not sure if this is posted in the correct location so feel free to move it. I did several searches and all I came up with is 'white pixel' issues and I have a single black pixel that will not change. It's right near the center of the screen and if it was off to the side, I might not notice it so easily, but now that I know it's there, I always seem to see it. Is there a reasonable fix? Anything else I can check?
Howard
Howard - AVS is offline
post #2 of 4 Old 05-13-2013, 05:55 PM
knobby's Avatar
it depends if the mirror on the dlp chip is stuck open or closed.it will show black or white.the only way to fix it is to replace the dlp chip.
knobby is offline
post #3 of 4 Old 05-14-2013, 05:03 AM - Thread Starter
Thanks for the reply. Will this get progressively worse rapidly or will I expect to see a dead pixel or two every 5 years or so?
I've built several home computers in the past, is replacing the DLP chip similar to assembling a motherboard etc?
Here's the big question, about how much is a new DLP chip?
Thanks alot,
Howard
post #4 of 4 Old 05-16-2013, 05:06 AM
knobby's Avatar
hard to say how long before another stuck mirror might appear.there is a lot of walk throughs on you tube and avs.there are also videos people have posted.i think the part runs about 100 bucks.just do a search and you should find a lot of help on fixing your tv.
knobby is offline
Reply Rear Projection Units
Samsung Hl67a750 67 Inch 1080p Led Powered Dlp Hdtv
